09 Fusion, Subframe/cradle won't lower
kipper667
Doing the DS control arms (upper & lower), tie rod, and hub bearing. Disconnected the steering column under dash, removed both cradle plates (L&R), lowered the jack and nothing. Cradle won't lower. loosened a front cradle bolt then the other and still nothing. The cradle will not move. I can put in a pry bar and make it wiggle up and down 1/4" but that's it. I've watched several vid thinking I missed something but nope, all they did was remove the 2 15mm bolts & the 1 nut on one side only and it dropped. But not mine. It feels like there's another bolt somewhere towards the center of the rear cradle but I see nothing. What am I missing?
