Ford recalling 65k Fusions from 2014 and 2015 because key can be removed
Houston
Ford is recalling an estimated 64,869 examples of the 2014-2015 Fusion, Fusion Energi and Fusion Hybrid in North America because the key can be removed when the vehicle isn't in Park under certain conditions. Specifically, the campaign covers 56,479 units in the US, 6,048 in Canada and 2,342 in Mexico, according to the automaker's tally on November 11.
Ford says a programming problem in the instrument cluster means that the key can be removed 30 minutes after the ignition is turned off, even if the transmission is not in Park. The situation where this could happen seems quite limited, and the company is not aware of any accidents or injuries related to the issue. However, the fault puts the vehicle out of compliance with federal regulations covering theft protection and rollaways, and must be repaired.
