After cleaning MAS I sprayed some CRC MAF cleaner into the wiring harness connector. It was tight going back on and when I pulled it off the red female piece stayed on the MAF sensor. Inside the wiring harness connector I saw a green rubber washer slightly out of place at the bottom.
I repositioned it and connected the harness (still tight) then secured it with the sliding clip. Car seems to be running ok.
I suspect the CRC cleaner unglued something or swelled the rubber in the connector.
Can I leave it like that or do need to get a pigtail harness repair kit?
Any advice or opinions are appreciated
