Rear Parking Sensor Problem .
fusion guy
Saint Albans
WV
2014 Ford Fusion SE Luxury Edition
2014 Fusion with factory rear parking sensors I have for scan paid version with the elm obd11 connector .
I use it to check for dtc's and there were non I ran a test on the module it came back fine .
When u put it in reverse a message pops up asking if u want to turn it off or on . It will no longer let me turn it on .
Any ides would help a bunch and thank you in advance .
North canton
OH
2013 Ford Fusion SE 1.6L EcoBoost
Have you tried disconnecting the battery to reset the system/Park Aid Module? Try going in with FORScan, and flash/reset the PAM... If it still isn't throwing any DTCs but still doesn't let you turn it on when backing up (greyed out), I'd recommend taking it to a dealer.
