Hi, my 2018 Fusion Titanium has 235/40R19,
I have 18” winter wheels that fit correctly. A tire size calculator says I need 235/45R18 for winter tires.
Can I use a 235/50R18 safely without effecting the Fusions systems? Thank you
You can put any size tire in your vehicle as you choose. I have 245/30ZR22 on my 2014. Just know using anything aside from your recommended/oem recommendations... ie: going with a 235/50/18 per your example is going to make your speedometer inaccurate. May I ask why you want to go to a taller profile? It’s a really odd tire size and in the event of a flat, you’re going to have a hell of a time finding a 235/50/18 vs a 235/45/18 and the size difference between them is negligible. Just not sure why you want a different size. 235/45/18 is my stock size. That would be my recommendation for your winter tires.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
