2015 Fusion losing power
Ken F
Louisville
KY
2015 Ford Fusion SE
Hi everyone, my name is Ken. I've never did the forum thing, I am at my wits end using Google and you tube. it's really hard to give a description to the sites. So I'm hoping someone out there can help.
OK, My wife's 2015 Fusion has been maintained very well. Now to the issue, one night she was driving probably around 10 miles, when the car lost power information came up as check owner's manual, wrench came on. once she came to a stop the engine was running but real rough. Would let it set for 10 to 15 minutes it would start right up and she could get another five mile until it would happen again. I've changed out the cylinder temp sensor. I seen on a you tube video that the engine has a fail safe in shutting down to prevent engine damage. put my reader on it and it threw a P2111. I cleaned the throttle body, re calibrated the body. check engine went thought I had Concord the problem. NOT has any one else had this problem.
I'll ask this first...
Does the condition still occur?
I'd also have someone inspect the radiator, serpentine belt and the coolant tank, make sure nothing is wrong.
When it "sputters" like that usually from a failure, as in a major failure. Could be wiring or something going thru the radiator and AC - .If not that, you replaced a temperature sensor. Not sure why you had to do that - but in doing so, might have upset the wiring, you may have forgotten to put something back on and it upset the system to throw that code - there may be more - later on. (I'm referring to codes it can show.)
The main premise here, is by your description of symptoms nd what you've had to do. This may also indicate a problem with powering a system - like the water pump - to keep the engine coolant flowing.
IF the pump is bad, you know what you need to do. If the belt came off - make sure all the pulleys are using it and the belt is threaded thru to make them turn - correctly.
EAST BERLIN
PA
2023 FORD EDGE ST
Take it to a Ford dealer and have a diagnostic ran, or master mechanic look at it.
CAVPILOT
Slaton
TX
2015 Ford Fusion SE AWD 2.0L
NOOB here and just came across this.
Mine had the SAME symptoms...loss of power on acceleration and sputtering. My fix was as simple as the EGR VALVE being plugged up. Replaced and all is well!
You bring up an interesting point.
EGR systems - for the Fiesta does not use one, but others do.
Not many stop by to help us out - thank you! For there are many smaller problems that can cause this condition and it brings out the best, or worst in us trying to track them down.
Consider this added to that list of things many don't think to check - glad you found your fix.
CAVPILOT
Slaton
TX
Did I accidentally post in the wrong forum?!? LOL
The SUBJECT states Ford Fusion but reading closer, I see, this is for the Fiesta! HAHAHAHA
It's OK, I sometimes visit the FOCUS forums to help find answers for some of our own "problematic" Focus' in our fleet of vehicles we use.
I oftentimes stumble onto and help pass along answers there too...
